Polyline Width
Polyline Width
Message 1 of 12
Polyline Width
I changed the  width in Layers & when i draw the line it still Thick.
I made shore Linewidth was on in customazine .
Replies (11)
Message 2 of 12
R_Tweed
Things you could check?
1. properties palette.
2. pline width "plinewid" system variable
Message 3 of 12
Already checked it,but line still Wide
Message 4 of 12
pendean
Community Legend
Community Legend
Post your DWG file, point to the object, lets all review it for ourselves: ensure you bundle your plot style table with your DWG file so we can see what else you may have missed.
Message 5 of 12
Where do i get the Plot Style Table?
Message 6 of 12
pendean
Community Legend
Community Legend
If you use ETRANSMIT command it will bundle all the necessary files along with your DWG in a ZIP file that you can post here.
Message 7 of 12
R_Tweed
First determine what plot style table  you are using by typing plot at the command prompt.
Type options at the command prompt, find your plot and publish tab (4th from left) and click on Add or Configure plotters. That will take you to a folder that has a folder names plot styles.
I just remembered that if you etransmit. Then those files will be included.
Message 8 of 12
Attached
Message 9 of 12
I get this error when i type Plot Style
Message 10 of 12
pendean
Community Legend
Community Legend
You did not read (or perhaps not understand) the entire reply you first got after you first posted: you have a PLINE with a WIDTH assigned, this needs to be set to zero instead if you don't want it to plot that thick
Message 11 of 12
Thank you for your help!
Message 12 of 12
R_Tweed
It looks like @pendean  has answered your initial question.  however, you might want to become familiar with plot styles at some point.
Type "plot"  and look at the upper right corner of the dialog box that appears.
