How to edit block without modifying the actual block in content browser?
bayleeliu
bayleeliu
It could be a bit confusing, so I am trying to edit a block from tool palettes and once I hit save the block gets automatically updated in the content browser too, so the original block is modified. Is there a way to edit the block without really touching the original one? Thanks!
pendean
Community Legend
Community Legend
You cannot modify the original source block from another DWG file using TPs. Sorry.
You can only create a second block from this newer source, the file you are doing all this editing in.
R_Tweed
I'm guessing a little here, so forgive me if I'm off.  There are a couple of ways to edit block definitions in published tool palettes without updating the source dwg.  Editing the block definitions of multi-view blocks or annotation tags, door symbols etc. is different.  Here is a  (screencast)
1. edit definition in current dwg only. right click and edit block.
2. save block as another block in the source file.
If you are looking to edit aca content, post a screenshot of the symbol, toilet, tub etc. So I can better understand.
