How can I make AutoCAD Architecture the default version when opening .dwg files?
s.v.d.heuvel
s.v.d.heuvel
I recently reinstalled AutoCAD after a long period of not using it, and I found out that the programme now has a version specifically made for architecture (maybe it already had it, I have just never seen it before).
Whenever I try to open a specific file however, it opens it using the standard AutoCAD profile, even when I do it by right-clicking the Architecture version on the taskbar to show recent files. Is there a way to set a default profile whenever you open a .dwg?
RSomppi
Use the program to open files.
s.v.d.heuvel
What do you mean? I'm trying to make it so that when I click on a .dwg file, it automatically starts AutoCAD Architecture instead of just the normal version of AutoCAD. Right now, I have to open AutoCAD Architecture first, and then click on the recent file from there. Are you saying that this is the only way to do it? If not, I don't understand what you are trying to tell me.
RSomppi
If you want to work on a file in a particular program, start the program and use the open file dialog within the program. It's not only a common practice but it is considered best practice by many, especially when you have multiple programs that can work on the same files.
imadHabash
I suggest to follow this official LINK that may help.
Imad Habash
Ed__Jobe
By default, AutoCAD will remember the last profile used. Just open ACA and then close it. The next time you double click on a dwg file, it should open in ACA.
Ed
How to post your code.
