File cannot be saved
prizmar
prizmar
Hello:
Working on my laptop outside, normally work on my desktop.
When I want to save my file a pop up  says ;
"one on more objects in this drawing cannot be saved to the specified format. The operation was not completed and not file was created".
Please help.
Thank you!.
pendean
Community Legend
Community Legend
What year version of ACA are you using?
Tiana_Y
Hi @prizmar
This error can show up due to many reasons, the most common is file corruption could you please give the following a try:
  • Use command AUDIT to repair the drawing.
  • Use SAVEAS or WBLOCK to create a file.
  • If the drawing immediately shows the error when saved, without changing something, insert the drawing into a new one created from the acad.dwt or acadiso.dwt template.
  • See also How to repair corrupt AutoCAD files.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
prizmar
Thank you Tiana:
Seems like there is a problem with the text, when I deleted I or change the font I was able to save, seems like in my laptop I am missing that font, any idea how to bring that font?.
Thank you again.
pendean
Community Legend
Community Legend
You need to find the font source file, then follow these directions to install them https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Where-to...
prizmar
Hello:
Thank you for the quick responses, I checked with support and my CAD program had some problems so they fixed remotely,
Thanks again
