FATAL ERROR Invalid Configuration path\filename:
Error Message.PNG  This error is occurring for a number of Active Directory users who are logging into a PC LAB with 30 desktops. We have over 200+ students whom use it and I can figure out why some work and some dont!
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
There are a couple of documented solutions for this problem here on AKN. Have you tried the suggestions in any of these?
It seems odd that it happens to some users and not others, if all things are equal in the lab environment. Give these a go and let us know if they point you in the right direction!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestions in the articles I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Hi Victoria,
Thanks for your time and attention on this issue I have been experiencing.
I have tried only a few solutions that you have offered, but I users are still experiencing this issue.
I believe that somewhere, a certain setting is affecting my roaming profile issue.
I will follow up as soon as I can. I hope that one of those solutions do work!
I can suggest an extremely helpful tool to resolve such issues is LongPathTool. Thank you.
