.downloading autocad architecture 2017 education
really having trouble downloading the autocad Architecture 2017 onto my computer . It has all the system requirements, but the installation keeps failing. Here is the log:
DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp
2016/11/5:08:10:14 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp\Setup\AcSetup.dll
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:10:13 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:10:20 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:10:34 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:10:34 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:12:50 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI47AD.tmp
2016/11/5:08:15:14 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AI47AD.tmp\Setup\AcSetup.dll
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:15:34 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:15:34 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:19:09 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp
2016/11/5:08:19:40 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp\Setup\AcSetup.dll
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:19:53 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:19:53 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:19:58 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:20:00 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:21:51 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp
2016/11/5:08:46:17 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp\Setup\AcSetup.dll
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:46:17 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:46:19 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:19 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:46:37 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:37 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:47:15 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:47:18 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:47:18 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:47:21 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:47:21 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Any ideas???
