.downloading autocad architecture 2017 education
really having trouble downloading the autocad Architecture 2017 onto my computer . It has all the system requirements, but the installation keeps failing. Here is the log:
DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:10:11 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp
2016/11/5:08:10:14 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AIB2E2.tmp\Setup\AcSetup.dll
2016/11/5:08:10:12 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:10:13 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:10:18 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:10:20 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:10:21 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:10:22 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:10:34 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:10:34 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:12:08 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:12:50 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI47AD.tmp
2016/11/5:08:15:14 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:15:12 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AI47AD.tmp\Setup\AcSetup.dll
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:15:13 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:15:26 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:15:29 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:15:30 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:15:31 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:15:34 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:15:34 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:17:05 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:19:09 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:19:38 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp
2016/11/5:08:19:40 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AI58A1.tmp\Setup\AcSetup.dll
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:19:39 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:19:43 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:19:53 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:19:53 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:19:54 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:19:55 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:19:58 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:20:00 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/11/5:08:21:27 rhbuc DESKTOP-V57EVJV PageOpen InstallCompleteDialog
2016/11/5:08:21:51 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV CommandLine /PK 001I1 /SN 900-34601172 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/11/5:08:46:15 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp
2016/11/5:08:46:17 rhbuc DESKTOP-V57EVJV === Setup ended ===
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV === Setup started on DESKTOP-V57EVJV by rhbuc ===
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Path_Length: 162
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Current Directory C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Launch
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\rhbuc\AppData\Local\Temp\_AIFA01.tmp\Setup\AcSetup.dll
2016/11/5:08:46:16 rhbuc DESKTOP-V57EVJV Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/11/5:08:46:17 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:46:19 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:19 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:46:37 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:37 rhbuc DESKTOP-V57EVJV PageOpen LaunchDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen LicenseDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen ProductInfoDialog
2016/11/5:08:46:42 rhbuc DESKTOP-V57EVJV PageOpen ProductSelectionDialog2
2016/11/5:08:47:15 rhbuc DESKTOP-V57EVJV PageOpen FullProgressDialog
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Install Universal C Runtime (KB3118401) Succeeded
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:47:16 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x86_2015.log
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\rhbuc\AppData\Local\Temp\vcredist_x64_2015.log
2016/11/5:08:47:17 rhbuc DESKTOP-V57EVJV Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2016/11/5:08:47:18 rhbuc DESKTOP-V57EVJV Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/11/5:08:47:18 rhbuc DESKTOP-V57EVJV Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/11/5:08:47:21 rhbuc DESKTOP-V57EVJV Install DirectX Runtime Succeeded
2016/11/5:08:47:21 rhbuc DESKTOP-V57EVJV Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/11/5:08:48:49 rhbuc DESKTOP-V57EVJV Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Any ideas???
David_W_Koch
Try using the Virtual Agent to download the software first, and then run the installation.  Depending upon what software you are downloading, there may be multiple files to download; download all of them to the same folder.  When all of the downloads are complete, double click on the "1" file, which will initiate the extraction of the installation files from all of them.
When the extraction is complete, the installer will start.  You can proceed with the installation (or deployment creation) then, or, if you prefer to do that later, you can cancel, and, when you are ready to install, double-click on the Setup.exe file you will find in the root folder to which the installation files were extracted.
I would recommend going through the procedures for performing a clean uninstall.  If you have other Autodesk software installed that is working properly, then do not delete the licensing files and, when directed to delete files or registry keys, only delete the AutoCAD Architecture 2017 subfolders in the locations noted.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
