Assuming that the compiled SHX file is not a font, you can use the LOAD command in AutoCAD to load the file, and then use the SHAPE command to place instances of the loaded shapes. Use the ? command line option while in the SHAPE command to see what shapes are available. Choose the default * option to see all shapes, or use a wildcard string to limit the shapes displayed to those whose names match the wildcard string.
If the SHX file is a font file, then you would have to have it located somewhere in your AutoCAD Search Path, and then set up a Text Style that references that font.
David Koch
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
