I seem to have lost the DoorStyles from the list. How can I get back?
Solved by David_W_Koch. Go to Solution.
Check the Schedule Properties and makes sure that the 'Door Styles' box is ticked under 'Applies To'.
Is the DoorStyles Property Set Definition in that drawing file? If not, it will not appear as a choice.
Also check the Applies To tab settings in both the Door Schedule Schedule Table Style and the DoorStyles Property Set Definition. The DoorStyles Property Set Defintion has to apply to styles of all of the objects to which the Door Schedule Schedule Table Style applies. (The Property Set can apply to more, but at least must apply to all of the objects to which the Schedule Table applies.)
