AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Difference between pdf result and view.
1 REPLY 1
staler.pc
418 Views, 1 Reply
Hi!
I have problem with converting dwg to pdf. On the pdf (on right) all objects is showed without transparency but in the autocad it is showed with transparency.
Why does it happen? How I can make pdf result with transparency?
Problem file was added.
Tags (2)
1 REPLY 1
David_W_Koch
in reply to: staler.pc
When you plot, you need to make certain that the Plot transparency toggle in the Plot dialog is checked.2018-05-25_Plot_PlotTransparency.png
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Forma Design Contest
