Detail Component error: "There are no detail component databases specified"
I renewed Autocad Architecture 2017 to 2018, when I try to  insert Detail Components I got this " There are not detail components database specified"
The AutoCAD instructions are very confusing
Please help.
@Anonymous for clarity VStudley edited the original subject: detail component help!
TheCADnoob
Victoria.Studley
Hi @Anonymous,
First, welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
I'm checking in today to see if you need more help with this. Did the blog post that @TheCADnoob provided help you fix the problem?
If not, you might also try the suggestions in this article: Error: "Cannot open database" in ACA or MEP Detail Component Manager
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
