copyclip and pasteclip commands don't work
I copy or cut to clipboard and when I paste, nothing happens, i.e. a blank. no error message.
leothebuilder
Did you try copy and paste in another application?
Did you try a restart of your computer?
Thanks for your input. I tried those.
pendean
Community Legend
Community Legend
Is this withina single file, or two files?
Is the problem in one file, or ALL files, even if you start a new file and draw a few things to copy/clip?
Look at the commandline: which is failing, the COPYCLIP or the PASTECLIP function?
Victoria.Studley
Hi @Anonymous,
It looks like @pendean provided a good recommendation here. Did that help you solve the issue with copyclip/pasteclip in your files?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
