Tapered Column cut plane
08:06 AM
We do a lot of pre-engineeered metal buildings. I've been able to improve our drawings by creating tapered columns and setting the cut plane higher (i.e. 8' AFF) than standard cut plane of the walls so that when a column needs to be "boxed in" the drawing shows the true depth.
When I have a mezzanine level I need the cut plane at a different level for the mezzanine plan. But when I change the cut plane it changes all the columns. I have both base floor plans in the same file.
Can I set the cut plane to be different for the same column block in the same drawing file?
