Converting 3d solid to mass element
I wanted to ask, why when I choose a bunch of 3d solids and convert them to mass, they are sort of combining together ? can I separate them?
thanks
andkal
Try this:
(This converts selected 3dsolids separately one by one)
(defun c:test ( / ss1 i1 e1)
    (if (setq ss1 (ssget) )
        (repeat (setq i1 (sslength ss1))
            (setq e1 (ssname ss1 (setq i1 (1- i1))) )
            (command "_MASSELEMENTCONVERT" e1 "" "_yes"  "" )
        );repeat
    );if
    (princ )
);defun
If you are not familiar with autolisp, just copy this code to Notepad and save as .LSP file, then "drag and drop" it into opened drawing to load it. Commands name is TEST
• www.autolisps.blogspot.com - Productivity plugins for Autocad and Autocad MEP
• Autodesk AppStore
