Block becomes tiny after simple layer change
gnarkill283
gnarkill283
All I did was change a layer of an attribute definition from one layer then back to its original and now all the blocks in that drawing are tiny. I've tried checking annotation scales and redefining the block from a dwg that shows the block correctly with no luck. Why would it do this?
gnarkill283
The new tiny block still changes in size when changing the model's annotative scale so it seems like the block itself has been reduced in size by 12 fold or something
pendean
Community Legend
Community Legend
Not possible: post a sample DWG file with that block for a closer review and explain in detail how you did what you did.
pendean
Community Legend
Community Legend
@gnarkill283 wrote:
.... like the block itself has been reduced in size by 12 fold or something
Did you change your dwg units from feet to inches?
gotphish001
I'm with Dean if it is indeed smaller by 12. Unless it's a crazy coincidence when something changes up or down by 12x it's usually something with inches and feet being changed.
Are you grabbing the block from a drawing and inserting into another and those drawings have different units set? One is inches the other is feet? I understand you said you just changed layers but things don't change on their own. It's got to be another step in there somewhere or another change elsewhere that you didn't realize affected this.
Nick DiPietro
Cad Manager/Monkey
Tiana_Y
Hi @gnarkill283
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean and @gotphish001 provided help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
