Why does my autocad shutdown when trying to open drawings that i have never opened? - my work partner can easily access them.
I need help ASAP,
Yes - that was yesterday's update- AutoCAD 2018.1!!! I hate things like this, but it happens what can you do. Thanks for your prompt response!!!
Hi Paul,
Apologies for the inconvenience caused.
Would it be possible to send us the sample drawing files that are shutting down AutoCAD.
Alternatively, you may send the drawing files at sridharDOTsubramaniATautodeskDOTcom if you prefer not to post the drawing on the forum.
I do not think it is the drawing - it practically is every single document that i opened. Everyone in our circle that has 2018.1 update installed has the same problem - then we uninstall it and everything is good.
The files are from a local machine/harddrive. I tried to open any file from within the software and by double clicking. I am using windows 8.1, but my partners are using 10 and the same problem. I also tried to restart which did not bare any fruit. There is a crash dialog, i did submit twice or so already - if that means anything.... I have to close of the dialog. No unique file names. We can have a call if you wish - you can call right now if you wish, also i should tell you that i did uninstall the update on all my machines and things are back to normal.
Thanks for your time - please do not worry about bothering me saturday,
Paul
Thank you again for reporting this issue to us. We believe this problem may affect a fraction of a percent of our users, but want to make sure that those affected have a solution in place as soon as possible. The problem only affects customers that open DXF files, with XRefs attached, that have certain specific attributes.
I am attaching the ACDB22.DLL file and some brief instructions to apply this hotfix.
To apply the Hotfix for AutoCAD, LT, or Vertical products crashing after applying Update 1 when opening DXF files that contain XREFs:
We will endeavor to include this hotfix in future updates, so if you have a newer update than Update 1 – 2018.1 – O.107.0.0, it shouldn’t be necessary to install this hotfix.
