Autocad keeps crshing
Hey guys,
My AutoCad is having a issues crashing when I do a specific task.
To put things in context, I am working on a railing detail set...I have a file from another company/project I'm using as a go by.  I created my views in project nav. and have created my model space views for each dwg.  The problem now is when I drag the model space views to my sheet cad crashes every time...the file sizes are btwn 300-400kbs, so they're not too big...I thought there may be an xref nesting issue so I purged the dwgs, didn't work...Not quite sure what's going on?
Jason
leothebuilder
Have installed all the latest service packs.
Does the crash happen only with these particular drawing files you are using?
Remember to purge and audit these drawing files.
Try duplicating the events with some basic drawings that contain a little content.
You need to narrow down where the problem lies.
If all this fails, post the problem files for someone to look at.
I ran the purge with no success, but when I did the audit it worked like a charm.
Thanks.
Jason
