Hi! In the past week one stone hatch I use has started glitching and not displaying correctly, all other hatches appear to be normal. I can make the stone hatch display correctly using the RE regen command, yet the moment I zoom in or out or move around the drawing the hatch glitches again. Any thoughts on what may be causing this?
Screenshots attached for reference:
Solved by rkmcswain. Go to Solution.
Set the hatch origin, near the hatch object in space.
Ref: Link
And to answer your question, it's the 35 year old code that's still in use today, combined with certain hatch patterns that exhibit this behavior more than others.
