Annotative Wall Hatches Not Displaying in XRefs (ACA 2020)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a couple people in the office having an issue with Annotative Wall Hatches not displaying when the walls are in an xref and I'm stumped. The only way the hatches appear is if they are not annotative, and a regular hatch pattern that is annotative works correctly.
For testing I opened the file that is being linked (2-BR), did a save-as (test) so the display config settings are the same, and then linked in the original version. As-is, no hatch patterns. If I edit the xref, then modify a wall type and make the hatching not annotative everything displays as intended. This all worked correctly in 2019 - so I would assume there is some setting that I'm completely overlooking here...
Cheers
