AM layers Turn off in Autocad Architecture
Akash_SAK✨
Akash_SAK✨
can someone please Help me how to turn off the AM layers settings in Autocad architecture, I have go through some articles I have found the same issue that fixed in Autocad Mechanical. it will be a great help if someone help me to solve this.
Thank you.
Akash Balaji
Detailing engineer, India
pendean
Community Legend
Community Legend
LAYER command has an OFF/FREEZE setting for layers you do not want to see, use that?
OR... you have MECH content in your file, so those AM layer will always reappear when you use and reuse that content. You need to permanently remove that AM content from your files (hatches etc.) and they will never show up again.
Also ensure your ARCH year version is fully updated too.
Akash_SAK✨
Hi, thanks for Reply
But, my cad file doesn't have any mechanical properties and the AM options doesn't show up in the first place.
the real deal is i didn't use the dimension layer that i set current for the future uses. is that any other way to get rid this off.
cadffm
@Akash_SAK  schrieb:
" and the AM options"
AM options are part of M;echanical, not of Architecture.
" i didn't use the dimension layer "
Why are you talking about dimension, I can't read about dimensions in your first post?
Are you talking about using DIMADD (Architecture dimensions) or adding AutoCAD Dimensions (like dimlinear) ??
If the issue is by using AutoCAD dimensions only, read more about DIMLAYER
Sebastian
Akash_SAK✨
this is my current layer that i wanna use if i take a dimension it automatically changes to AM5 layer as below.
i Didnt have any mechanical properties in my cad file so why am I getting this??  and also there is someone at mechanical forum faced this same issue please refer the link for more.
(https://forums.autodesk.com/t5/autocad-mechanical-forum/whats-the-deal-with-the-am-layers/td-p/33656... )
Thankyou.
cadffm
Again: Check your DIMLAYER setting
because you are using plain Acad dimensions
Sebastian
Akash_SAK✨
Thankyou sir this worked.
