ACA 2013 - Elevation Bug?
Hugh_Compton
Advisor Advisor
Message 1 of 53
Hugh_Compton
I've attached a file with a 2D elevation.  The hidden lines are created as continuous lines.  This always worked fine in previous releases.  Is this a bug or have I done something wrong?
Replies (52)
Message 21 of 53
Oh wow I have the same problem. glad I found others are running into it to. Tooks me weeks just to find the right forum. Hope this is resolved!
Message 22 of 53
Autodesk have sent me a hotfix that has solved the problem.
Message 23 of 53
AbilioLopesAlmeidaJr.2603
Herman,
Can you post the link? Could not found it in update section.
tks
Message 24 of 53
The hotfix was with a responce from my subscription Autodesk support team.
I'm not sure if I can post it on this site.
Message 25 of 53
I would have expected to find it in "AutoCAD Architecture Services & Support" updates & downloads but it is not there at this time.
Message 26 of 53
I think the Autodesk support team will know what operation system hardware you are using.
Message 27 of 53
Herman,
I am using windows 7, 64 bits. Are you using the same? I realy need this fix as soon as possible.
tks!
Message 28 of 53
Draftdoug5610
Post the fix, post the fix, post the fix.... come everyone now....
Message 29 of 53
hausbau-planung_de
you can read here, but attention, it is the german version.
http://bimblog.typepad.com/autodesk_bim_blog/2012/04/darstellung-von-schnitten-autocad-architecturem...
A. Zimmermann
www.hausbau-planung.de
Message 30 of 53
Centrelinearchitecture
it's been a month since the original post and still no fix???
Message 31 of 53
MichaelBussiere2
Hello All,
This issue is one we have been working diligently on and have developed a hotfix that will be released very soon.  Please be on the lookout via your communication center notifications (top right of UI), Subscription Center, and the support landing page for ACA on www.Autodesk.com.  Thank you.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Message 32 of 53
barbara.schurig
Autodesk Support
Autodesk Support
The Hotfix is now available at our website.
Please check out this link:
Section Hotfix 2013 ACA AME
This works for AutoCAD Architecture and AutoCAD MEP 2013 and all languages.
Best regards,
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 33 of 53
The hotfix did not work for me. I followed the instructions and now none of my AEC objects work and I can't load the content browser. I removed the hotfix and everything is back to the way it was. Has this hotfixed work for anyone else?
Message 34 of 53
Hugh_Compton
So far it has worked on all of my tests.
My machine = Windows 7, 64 Bit.  English version of ACA.
Message 35 of 53
barbara.schurig
Autodesk Support
Autodesk Support
I tested it with W7 64-bit German and English release. The hidden objects are not visible and also Content Browser pops up as usual, I can search and drop objects into a palette.
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 36 of 53
Strange. I'm running W7 64 bit as well. I'll redownload and try again.
Message 37 of 53
At last. Nice but it took longer. Moreover German version out 24 hours before English version. This might have prompted Autodesk to release the following day. Thanks to the German version.
Message 38 of 53
barbara.schurig
Autodesk Support
Autodesk Support
This hotfix works for all languages. There is no "English" or "German" version, I just want to clarify this so no one gets confused.
All of you can use the hotfix in the AutoCAD Architecture or AutoCAD MEP 2013 download area, no matter what languages you are using.
Cheers,
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
Message 39 of 53
ntellery
I doubt that would be the name of the folder
"C:\Program Files\Autodesk\AutoCAD 2013."
just picking !!
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
Message 40 of 53
barbara.schurig
Autodesk Support
Autodesk Support
the folder name is correct. With 2013 release AutoCAD Architecture and AutoCAD MEP had been modified and several AEC related files are now stored in the AutoCAD folder.
The benefit of this is, a much faster installation when AutoCAD Architecture or MEP are installed on a system where AutoCAD has already been installed. Or if AutoCAD Architecture was installed, MEP installation will run so qiuck that you might doubt that everything installed.
Cheers,
Barbara
Barbara Schurig
Support Specialist
Product Support
Autodesk, Inc.
