AutoCAD 2000/2000i/2002 Archive (Read Only)
import acad dwg in adobe indesign!!
3 REPLIES 3
24240 Views, 3 Replies
Hi!!
IS there anyone who knows, whow to import acad dwg files in adobe
indesign ( which filter to I need and where can I get this filter)?
thanks
heinrich
3 REPLIES 3
you cannot import it to InDesign but you can import AutoCAD drawings (up to
2000) in Illustrator 9 and you can export from Illustrator as dwg as well.
You could import into Illustrator and then bring the Illustrator file into
Indesign.
Regards
Finnur P. Frodason
"Heinrich Sickl" wrote in message
news:3AF28C8E.20F89391@xarch.tu-graz.ac.at...
> Hi!!
> thanks
> heinrich
Start PLOTTERMANAGER in AutoCAD, and set up new plotters that plot to file,
using any of the postscript drivers found under Adobe, to create EPS files
that you can import into Adobe inDesign.
Set up the final output file parameters, then all you need to do is use the
PLOT command, select this 'plotter', use any Plot Style Tables you want, and
Voila!
Or, explore setting up Raster File Plotters, same method as above, to
generate Raster files from PNG to TIFF.
HELP in AutoCAD will explain all.
Dean Saadallah
www.pendean.com
> Hi!!
> thanks
> heinrich
The direct plot-to-EPS-file method gives blank illustrations with a frame
only (they have no preview) - not pleasant to work with in a DTP program.
The preview can be added to an existing PS file with GhostScript (+GSView
for ease of use). The lineweights should be carefully chosen with this
method to get a readable final illustration (the illustration could be much
smaller than a 'normal' plot).
The AutoCAD -> Illustrator -> Indesign path gives much more flexibility and
control. There are various ways to get an AutoCAD dwg in Illustrator: WMF
export from AutoCAD or plot to PDF and open in Illustrator, or open the dwg
in Illustrator 9. Each has pros and cons.
Govert
Dean Saadallah schreef in berichtnieuws
F2D4CB4953186A8216E2B2E1F8461240@in.WebX.maYIadrTaRb...
file,
the
and
> Voila!
> Dean Saadallah
> www.pendean.com
> > Hi!!
> > thanks
> > heinrich
