Is it me or is it a BUG?
In the "Open" menu select the "Tools" menu select "Add to favorites" select
the directory, now if you pick on the "Favorites" icon to list the favorites
it's not there. It added it as a "Shortcut" but does not display it. The
"Favorites" is only showing the "File Folders" not any Url's or Ink's, 2000i
showed both of these.
Before you could add the lnk with "oShell.SpecialFolders.Item("Favorites")".
I see you can use the "Add Current Folder To Places" is this meant to
replace the Favorites? If so, Favorites shouldn't be on the menu if you
can't select a Url or Ink.
Bug??
Terry Hickman
Star Building Systems
"Terry Hickman" a écrit dans le message
news: B74303EE06E669076CC2F03EF09C3599@in.WebX.maYIadrTaRb...
select
favorites
2000i
As I tested it, drawings or folders shortcuts are not added to
"Favorites/Autodesk/" but to "Favorites/".
(o)-(o)
---ooO---(_)---Ooo--------------------------
Afitec France http://www.afitec.com
AutoCAD community http://communities.msn.com/AutoCADusersforum/
