Error with Wintab Compatible Digitizer
Whenever I open a drawing, I get the message "Error with Wintab Compatible DIgitizer. Contact your digitizer vendor for a copy of the Wintab software." The odd thing is that I'm not using a digitizer. So there's no digitizer vendor to contact. How do I stop this message from appearing?
Thanks! Karen
In addition to any replies you might receive or have already received, you may find more information or responses by posting future pointing device or display related questions in the following discussion group: By NNTP discussion group reader at news://discussion.autodesk.com/autodesk.autocad.digitize-display By HTTP (web-based) interface at http://discussion.autodesk.com/forum.jspa?forumID=17 Also try searching the Knowledge Base http://support.autodesk.com -- Tracy W. Lincoln Autodesk Discussion Group Facilitator Discussion Group Index: http://discussion.autodesk.com "beadgem" wrote in message news:[email protected]... > Whenever I open a drawing, I get the message "Error with Wintab Compatible DIgitizer. Contact your digitizer vendor for a copy of the Wintab software." The odd thing is that I'm not using a digitizer. So there's no digitizer vendor to contact. How do I stop this message from appearing? > Thanks! Karen
This should be easy to fix. Go to "Options". Look in the "System" tab (should be the fifth one tab). The second group down on the left side is the "Current Pointing Deivce" box. It's probably set to "Wintab Compatible Digitizer ADI 4.2 - by Autodesk". Change that to "Current System Pointing Device". Then hit "OK" at the bottom and you should be all fixed up. Joel
Thank you, Joel! Your suggestion worked perfectly.
