creating title block attributes
bill486
bill486
I have been using AutoCAD for a while now & I want to take an existing title block and create it into one that is an editable template so I can type in the drawing number, title, and other things related to the drawing.
Create your titleblock in modelspace, replace the text with attributes. Use
attdef to create them. When you insert this into a drawing file you are
prompted for the attribute values. I prefer to xref my Titleblocks into the
layout tabs, that way I can enter the information that is the same on each
sheet one time. I then insert a serperate sheet info block into each layout
that has info like sheet number which would be different on each sheet.
Chip Harper
Autodesk Discussion Group Facilitator
http://home.comcast.net/~hot4cad/
