Xref's not loading
Xref's not loading
Xref's not loading
I have a problem in AutoCAD 2002. My file has a bunch of references to other files and images and for some reason they aren't loading even though the files exist and it has the correct path. My parent file resides on one server and the references are on another server. We recently did a server upgrade and I had to remap to the network drive and since then I have had this problem. The saved path is still pointing to the correct location. Any ideas?
You so re-loaded the XREFs to make sure? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Hello and thanks for the reply,
The problem is I would have to reload a lot of images/xref's and I don't want to have to do that since there are a ton in these files. I am curious as to why it happened and hoping for an easier way of reloading them.
-Dave
If reloading fixes the problem, then either the PATH to them was not found, or someone changed the names of the files or folder etc. But you have to reload, or repath and reload, to figure out where the break is. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
