When importing a drawing into Artcam to set up for cutting on CNC some of the cutting is shown on the inside of the objects, others on the outside, even though I have selected outside for all? Can anyone help please?
Hi @Anonymous,
What version and build of Autodesk ArtCAM are you working in? To confirm this, select the Help > About Autodesk ArtCAM menu option in your ArtCAM software. For example, Autodesk ArtCAM Standard 2018 (Version: 2018.0.0 Build: 2017-03-30-0901-b7123cac7).
What type of file are you importing (for example, EPS), and what method are you using to import the file (for example, selecting Vector > Import menu option)? Please confirm.
I think you'll find the answer to your question regarding your Profiling toolpath here, although you'll need to select Outside as the Profile Type instead of Inside.
If you have any further questions, please do not hesitate to ask. Otherwise, please be so kind as to accept my response as a solution. Thanks in advance for your time and cooperation.
Kind regards,
Hi
Version and build of ArtCAM is: Express 2015, R2, 64 BIT 848, Feb 23 2016
Importing: DXF files
Method to import: Select vectors, import vectors preserving layers
Kind regards
Wendy
Hi @Anonymous,
You aren't using the latest build of ArtCAM Express 2015 R2 available to you. Please use the following steps to update from ArtCAM Express 2015 R2.SP2 (64-bit build 848) to ArtCAM Express 2015 R2.SP3 (64-bit build 860):
Your issue should be resolved by following the instructions given here, although you'll need to select Outside as the Profile Type instead of Inside. If you encounter any additional issues, please attach your ArtCAM Model file (*.art) when replying to this post so that we can investigate further.
To protect your privacy, I do not recommend that you share your personal contact information when posting to the Autodesk Community; I have removed any sensitive information from your previous post.
Kind regards,
