New openpbr_surface node material refraction display issue.
66175545
66175545
Can you please tell me, when I use the new openpbr_surface node material, I use the preset glass material, but how does the actual effect feel like it doesn't project? (It's only logical that the refractive material in front will project the gold material behind it).01.jpg
lee_griggs
Does it look the same with standard_surface? How does it look without specular_roughness?
Lee Griggs
Arnold rendering specialist
AUTODESK
Thanks for the reply, it's the same. I meant it didn't feel as through.
lee_griggs
Maybe it's just the camera angle. Can you see the gold sphere if you enable thin_walled?
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_user_guide_ac_openpbr_geometry_html
Lee Griggs
AUTODESK
Ok, thank you very much for your careful guidance, I will learn.
