Arnold GPU - Can't get a noise free render when using Mesh Light or Emissive Material
spencermullerdiniz
Message 1 of 17
spencermullerdiniz
Hi all,
I've been tinkering a bit with Arnold GPU renderer and I can't get results equivalent to CPU rendering when rendering a simple scene that contains mesh lights or emissive materials.
I get a lot of noise from mesh lights or emissive materials when using GPU rendering.
I followed all of the suggestions regarding AA samples and adaptive sampling, but still get a very noise result when using GPU renderer.
See tests below.
Any ideas how to fix this?
GPU Renderer:
GPU Renderer (Adaptive Sampling / 100 AA Samples Max / Adaptive Threshold: 0,01
CPU Renderer:
Replies (16)
Message 2 of 17
JohnDraisey
I'm curious now, I'll see if I can recreate this issue.
Message 3 of 17
madsd
I just tested it in the latest build, I cant repo, with either emissive or mesh lamp, they both come out clean after some seconds.
The emissive stops premature however, and it does not respect adaptive high samples, it looks like its clamped, but no fireflies, it just stops iterating
Message 4 of 17
Can you add the test scene?
On Arnold version 3.1.26 it runs fine.
Message 5 of 17
spencermullerdiniz
Hi all,
Here's the test scene and also the latest render using version 3.1.30.
Still reproducible.
Since I'm getting an error uploading the file ("Error parsing uploaded file" ), here's a download link:
TestScene.zip
Spencer
Message 6 of 17
madsd
I was able to correct the issue.
You use Linear exposure which for some reason introduces a ton of fireflies.
Setting to non or Physical instantly removes them.
Yeah so I can actually go back to linear, after some thing has been reset. and fireflies are gone.
So it seems you have injected a glitch into the file, that can be reset with this simple manouver.
https://imgur.com/a/xAczlb
Message 7 of 17
spencermullerdiniz
Nice! Thanks for taking the time, @Mads Drøschler.
I'm very amateur and would never think that exposure settings could affect a render this way.
Message 8 of 17
spencermullerdiniz
@Mads Drøschler, just got home from work and tried the workaround you proposed (changing exposure control to physical), but I'm still getting noise + fireflies. The only way I can get rid of them is by using CPU rendering.
Can you share the fixed scene file so I can check it out... See if it works on my end.
Message 9 of 17
madsd
https://www.dropbox.com/s/sjimmty0ppdsr44/lamps.zip?dl=0
2 scenes 2 different setup.
Also, I added a screenshot to show you how to manage fireflies in general.
You lower the Indirect AA clamp from 10 down to 3-4 or 2 if you want to dig deeper.
Message 10 of 17
spencermullerdiniz
I used the files you sent and compared with my original scene.
Seems quite a few things changed, but what really made the difference was increasing the intensity of the mesh light. In the end, I changed exposure to Physical Camera and tweaked the intensity of the mesh light to get a total intensity of around 16000. Intensities lower than this would start rendering fireflies.
Thanks for taking the time...
Message 11 of 17
Hello. I finally got gpu for rendering. You have to set clamping to minimum. Then you will have exact render as cpu. Cheers.
Message 12 of 17
spencermullerdiniz
What clamping are you referring to @vedran?
Message 13 of 17
lee_griggs
GPU or CPU, intersecting lights with geometry is not recommended.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 14 of 17
Under adaptive sampling in Maya 2020. But then reflections are black. No good. I also have ton of fireflies. I don't know why. I will ask a pro.
Message 15 of 17
Hello, I also have ton of fireflies with gpu. I use only directional light. Can you please help? I use Maya 2020. Thank you.
Message 16 of 17
madsd
Create a new thread so we don't need to do it in a nested dialouge on a case that is solved.
Remember to post images and descriptions of your problems as detailed as you can understand/get the situation.
Message 17 of 17
how can we do this in houdini?
