Trace Set not working with SSS Shaders
arnold_user123
arnold_user123
Hey There,
I have a simple scene of 2 cubes and an area light. I have setup my trace set so the green cube should not cast onto the red cube. This works as intended with a standard surface with no sss, but when I add sss, it no longer works, see reference images:
Working trace set - no sss on red cube:
SSS on red cube breaking the trace set:
However, if I set the object to be thin walled, the trace set begins working again.
Here is the very basic shader setup on the red cube:
Is it possible to use an arnold trace set in conjunction with non-thin walled SSS shaders?
This happens both in maya and katana
Thank you
arnold_user123
Added detail, this is using MtoA 5.3.3.3 and KtoA 4.2.3.3, Arnold 7.2.3.3
Stephen.Blair
Hello arnold_user123
SSS doesn't use the trace_sets mechanism, SSS uses the sss_setnames
// Stephen Blair
// Arnold Renderer Support
arnold_user123
SSS_setnames as I understand it refers to unifying several objects' ss properties to aid the blurring/smoothing at intersections
Does this mean if I want to achieve the same affect as the first image, removing the shadow being cast from an object onto an sss object, that is not currently possible?
Stephen.Blair
SSS doesn't use the standard trace sets, so no.
// Stephen Blair
arnold_user123
Is there another possible way to achieve the same effect, without trace set? Perhaps with a ray switch?
I know I can turn off shadow casting for an object, but that stops casting from that object onto any object, as opposed to a specific one. Same with a ray switch
If anyone has any ideas that'd be great!
