Trouble Denoising AOVs with noice
ethan.crossno
ethan.crossno
I'm working on getting a noice denoising workflow setup at our studio and I'm running into some problems. I've got an EXR that I have rendered with 2 light AOVs lgt_blue_bty and lgt_red_bty. I have a variance AOV for each of these lights as well which is just the same LPE with the variance filter. I've been reading through the docs and I cant see what I'm doing wrong here.  I'm including the EXR file that I have for testing. Maybe someone can tell me what's wrong with the EXR file I have.
This is the noice command I was running:
"C:/Program Files/Autodesk/Arnold/KtoA_4-2-2-0_katana_6/Libs/../bin/noice" -i "E:\Tempest\denoise\arnold_denoise_test.exr" -o "E:\Tempest\denoise\arnold_denoise_test_denoised.exr" -l lgt_blue_bty -l lgt_red_bty -t 44 -pr 3 -sr 9 --variance 0.5 -fe brz_albedo -fe N -fe Z
Arnold: Arnold 7.2.2.0
Katana: KtoA 4.2.2.0
Windows 10
Stephen.Blair
Is this what you got?
C:\Users\blairs>%MTOA%\bin\noice -i C:\Users\blairs\Downloads\arnold_denoise_test\arnold_denoise_test.exr -o "c:\temp\arnold_denoise_test_denoised.exr" -l lgt_blue_bty -l lgt_red_bty -t 44 -pr 3 -sr 9 --variance 0.5 -fe brz_albedo -fe N -fe Z
noice 7.2.5.0 [9c493421] - the Arnold denoiser
Up to 2 custom RGB feature buffers can be used while denoising, using the first 2.
Using "brz_albedo" as a feature buffer to guide denoising (instead of "denoise_albedo")
Using "N" as a feature buffer to guide denoising (instead of "N")
Using 32 threads.
Loading images...
Loading file "C:\Users\blairs\Downloads\arnold_denoise_test\arnold_denoise_test.exr".
Could not find associated AOV "RGBA" for channel R
Could not find associated AOV "RGBA" for channel G
Could not find associated AOV "RGBA" for channel B
Could not find associated AOV "RGBA" for channel A
Could not find associated AOV "RGBA" for channel lgt_blue_bty.R
Could not find associated AOV "RGBA" for channel lgt_blue_bty.G
Could not find associated AOV "RGBA" for channel lgt_blue_bty.B
Could not find associated AOV "RGBA" for channel lgt_blue_bty.A
Could not find associated AOV "RGBA" for channel lgt_blue_bty_variance.R
Could not find associated AOV "RGBA" for channel lgt_blue_bty_variance.G
Could not find associated AOV "RGBA" for channel lgt_blue_bty_variance.B
Could not find associated AOV "RGBA" for channel lgt_red_bty.R
Could not find associated AOV "RGBA" for channel lgt_red_bty.G
Could not find associated AOV "RGBA" for channel lgt_red_bty.B
Could not find associated AOV "RGBA" for channel lgt_red_bty.A
Could not find associated AOV "RGBA" for channel lgt_red_bty_variance.R
Could not find associated AOV "RGBA" for channel lgt_red_bty_variance.G
Could not find associated AOV "RGBA" for channel lgt_red_bty_variance.B
Using feature AOV 'brz_albedo'
    Filters for feature and light AOVs are different: denoising works better with matching filters.
Using feature AOV 'N'
Using feature AOV 'Z'
Working with 1 frame at 1x1
   Could not find AOV with source lgt_blue_bty
Could not find AOV "lgt_blue_bty" to denoise, skipping.
   Could not find AOV with source lgt_red_bty
Could not find AOV "lgt_red_bty" to denoise, skipping.
Warning: some output paths were ignored, since outputs always follow the input file layout.
Start denoising (patch radius 3, search radius 9, variance 0.5)
Finished denoising
// Stephen Blair
// Arnold Renderer Support
ethan.crossno
Yes that is the error I was getting. Seems like its not finding the channels or something like that.
JWRodegher
Did you ever figure this out? I can't make it work. I have all my aovs in different exrs and I can't seem to be able to denoise lightgroups (I'm using the -l flag).
