standard surface water material question
mhouse777s
mhouse777s
Is this a correct set up for water depth falloff? I feel like it's close but not optimal. Any help is appreciated. Insert photo doesn't seem to be working so I attached the image.
Thanks.
lee_griggs
You should be able to control the appearance using transmission_depth and transmission_color without having to use a falloff map. https://docs.arnoldrenderer.com/display/A5AF3DSUG/Transmission
Lee Griggs
Arnold rendering specialist
AUTODESK
mhouse777s
...so transmission_depth makes the water more opaque as the pond gets deeper? That's what I'm shooting for.
lee_griggs
Yes, here:
Lee Griggs
AUTODESK
