Arnold General Rendering Forum
Multiple lights in on shadow pass to be post animated in compositing?
2 ANTWORTEN 2
Nachricht 1 von 3
quentinluna1
189 Aufrufe, 2 Antworten
Hi guys,
I am looking for a way to animate in nuke a shadow pass with multiple light in it. As we could do it with lights using RGBA_*, turning them on and off by gaining them up and down.
I can play with the RGBA_default, but cannot play with each shadow separately.
Any thought would be greatly appreciated :leicht_lächelndes_Gesicht:
Cheers!
2 ANTWORTEN 2
Nachricht 2 von 3
lee_griggs
als Antwort auf: quentinluna1
Which plugin?
MtoA has Per-Light AOVs and MAXtoA has light/shadow groups, for example.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 3
quentinluna1
als Antwort auf: lee_griggs
@lee_griggs thanks for your answer!
Actualy using HtoA. Shadow group is used to avoid certain objects casting shadow right?
What I'd like to aim is have a per shadow AOV using shadow catcher to kinda reproduce what you get with per light AOV that you can then play with in nuke, like RGBA_key/env... That you can then grave in nuke.
Thanks!
