Render Passes for proper compositing when using aiatmosphere
emely123xyz
emely123xyz
HI,
I am trying to render a scene with aiatmosphere. Beauty render looks gret and the obivous passes (diffuse, spec, sss, AO; Z) are included. I am wondering which AOVs are missing to get a proper compositing looking the same like the beauty. I tried volume opacity (no other volume AOV had any content) which does not work in compositing at least if I am trying to add the opacity in aftereffects it never looks the same than the beauty layer.
Any advice?
Kind regards
Emely
CiroCardoso3v
Should be the volume for atmospheric.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
emely123xyz
No unfortunately anatomischere is not visible in the volume passes
CiroCardoso3v
Maybe @Stephen.Blair can have some input since he is the expert in Maya.
Ciro Cardoso
metatoma
you'll find your aiAtmosphereVolume within the emission AOV.
so if you have emissive objects in your scene, i would recommend to create a separated render layer for it!
emely123xyz
Ok thank you
lee_griggs
Example here.
Lee Griggs
Arnold rendering specialist
AUTODESK
