Easier way to create a procedural grid with individual tiles that can be larger than 3x3?
madsd
Can you show an example?
Something like the tiles in this wood shader
madsd
If you can load OSL shaders, I can try cook up a solution one of the next days.
yes i can load osl shaders, thanks...
madsd
Ok.
I compiled a base for the planks.
There is a float value called PlankLength which is the only variable except UV info I have hooked up.
For now, its a fully self contained procedural noise pr brick, there is also a grout scaler which is also fully procedural ( the noise is build into the shader directly )
I will look at wiring things out so you can use textures, as input pr tile at a point.
Just figured I would upload what I got for now.
Copy this to a clean osl shader and compile it, and hope it works.
// Complied by Mads Drøschler 14.3.2019
vector fract ( vector x ){
return x-floor(x);
vector hash3( vector p )
vector q = vector( dot(p,vector(127.1,311.7,0)),
dot(p,vector(269.5,183.3,0)),
dot(p,vector(419.2,371.9,0)) );
return fract(sin(q)*43758.5453);
float iqnoise( vector x )
vector p = floor(x);
vector f = fract(x);
float va = 0.0;
float wt = 0.0;
for( int j=-2; j<=2; j++ )
for( int i=-2; i<=2; i++ )
vector g = vector( float(i),float(j),0 );
vector o = hash3( p + g );
vector r = g - f + o;
float d = dot(r,r);
float ww = pow( 1.0-smoothstep(0.0,1.414,sqrt(d)), 1. );
va += o[2]*ww;
wt += ww;
return va/wt;
shader ProceduralTiles(
point Po = P,
float PlankLength = 200,
output color Out = 0,
output color OutA = 0,
float zoomout = .3;
vector uv = Po/zoomout;
float distortion = (iqnoise(uv/128.));
uv += (distortion*(15.*zoomout));
vector col = vector(0.5);
float a = (iqnoise(uv/4.)/2.)*2.;
col *= a+(iqnoise(uv/64.)/2.);
float mx = mod(uv[0],PlankLength);
float my = mod(uv[1],100.);
if ((my < 20.) ||(fmod(uv[1],200.) < 100. && mx < 20.) ||(fmod(uv[1],200.) > 100. && mx > 100. && mx < 120.)){
a = iqnoise(uv)/2.;
col = vector(.4+a);
Out = pow(vector(col),2.2);
// OutA = a;
ok i'll try it...thank you..good luck on finishing.
