Arnold General Rendering Forum
CustomAOV + AtmosphereVolume bug?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Andrew_Wilkins1
306 Aufrufe, 2 Antworten
When creating a simple custom AOV with an aiUtiliy shader set to UV mode. Alone that works as intended, but with the addition of a "aiAtmosphereVolume" environment shader (completely zeroed out) it greys out the custom AOV.
Is this a known issue?
MtoA 3.1.2.1
Arnold Core 5.2.2.1
Maya 2018.2
Andrew
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: Andrew_Wilkins1
If there's an atmosphere, then the aov shaders are evaluated as atmosphere shaders instead of as surface shaders. That's by design.
If there is a background, then it would be evaluated as a background shader.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
Andrew_Wilkins1
als Antwort auf: Stephen.Blair
Okay thank you!
The issue comes in with a scene that has a volumetric render layer which requires an atmosphere shader, but the other render layers need this custom AOV to function correctly.
I will do a connection override instead to "turn on" the atmosphere shader for that individual layer instead.
