- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I started experimenting with the Optix denoiser and came to the following issue.
I want my beauty pass to be denoised.
So I add the RGBA pass and check on the denoise box.
From that point on the optix works perfectly together with IPR.
BUT
When I want to render out a still image. I first get the following error:
// Error: [aov] more than one output statement was associated with single layer driver: defaultArnoldDisplayDriver@renderview_display //
the solution for this is to simple rename the aov but the moment I rename the aov,
it loses connection with the data from arnold for some reason because I don't get the beauty pass anymore.
It renders out blank images. Even in the IPR i dont get the correct result.
Is this a bug or am I doing something wrong?
tech info
(running maya2017 - and Geforce 1060 with latest driver)
