AO shader causing black lines on seams
litote
Message 1 of 1
litote
I used this method to create a texture from AO:
Add a aiArnoldAmbientOcclusion (Arnold-Shader) shader to the mesh.
Select the mesh and go to Arnold menu-Utilities-Render Selection to Texture. In popup set a Resolution and the directory. Hit Render button (it will render as .exr with name taken from mesh).
However, when I add the texture to a shader it shows black lines along the UV seams. On post suggested to unpremultiply the image. If this is the way, how does one do it?
Any other suggestions?
Replies (0)
