Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Viewport 2.0 display shader on standins
2 REPLIES 2
Andrew_Wilkins1
545 Views, 2 Replies
Does anyone know if there is a way to ensure that viewport shaders (basic colours via a Standard Surface) are viewable in the viewport on Standins?
I've tried applying the shader before standin export as well as assigning directly to the standin. I know calculations are deferred until render time but the issue comes in when an artist needs to visualize assets in the viewport when adjusting or set dressing and everything is grey.
Andrew
Tags (2)
Labels (2)
2 REPLIES 2
I believe this will be improved in a future release. Maybe colored display layers could help meanwhile.
Lee Griggs
Arnold rendering specialist
AUTODESK
Okay, always nice to get confirmation. Thanks for the suggestion for using display layers, I'll check it out.
I'm guessing this could a similar thing to Viewport 2.0 lighting information on Standins? ie. shadows cast from assets etc.
Technology Administrators
