Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
tangent space normals output
2 REPLIES 2
joie
1202 Views, 2 Replies
Hi there,
I want to out the normal color of my object in order to use in other nodes.
The utility shader outputs normals, but they are in object space and I need them to be in tangent space.
Is there any way to output tangent space normals instead?
Thanks in advance for your help.
Labels (2)
2 REPLIES 2
madsd
in reply to: joie
Space Transform could potentially solve it.
Ignore its 3ds max.
It should sit in the "math" section, down in the bottom.
joie
in reply to: joie
Mmmm, it's surely my ignorance, but I can't get this node to do anything. I've read the documentation but it's cumbersome to me.
If I plug the color output from an utility node set to "normal" to the "input" of the space transform, I get always black color.
Could you elaborate your answer a bit more?
