Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Render time problem in maya
4 REPLIES 4
506 Views, 4 Replies
any help
for rendering as my scene takes 157 minutes to render at 1080p with light sample rates at 3 and arnolds settings all camera aaa, specularity and all have up to 44
My textures are 2k and have a ryzen 2600x as a cpu
Using Maya 2020
Below is my scene rendered and the settings. my aim is to have a noiseless scene with less render time any help?
Tags (2)
Labels (2)
4 REPLIES 4
lee_griggs
I presume that is a typo?
>My textures are 2k
Are you converting them .tx textures?
Are those spherical lamps in the center mesh lights?
I don't see any surfaces with transmission roughness or SSS so maybe you could lower the transmission and SSS samples?
Have you tried the imager_denoiser_noice?
Lee Griggs
Arnold rendering specialist
AUTODESK
hyperviktor
Shouldn't take much longer than 5-10 minutes.
To check turn off all lights and have a single point light in the middle, that will give you a good baseline of the render time.
Then start adding back your lights and you will see where render time starts to peak.
in reply to: lee_griggs
all textures are tx converted. most them are all mesh lights using a sphere and an area light
additionally, i have a lot glass in my scene
