PolyMesh To Volume Lee Griggs' Tutorial
Message 1 of 19
Hei Everyone,
I've been trying to follow the tutorials of Lee Grigg's PolyMesh To Volume:
https://docs.arnoldrenderer.com/display/A5ARNTUT/Polymesh+to+Volume
However, I am encountering some problems and I hope some of you could help me with this...
-Whenever i convert my polymesh to volume and I render it, this becomes really noisy and greysh(even though I set the color material to full white), while Lee's one is completely white and doesn't show any noise whatsoever..
-The main problem is, whenever I assign the displacement to the model and I render it, I encounter the problem shown in the image below(The mesh is open on the mouth , but before applying the displacement it renders just fine, I even tried with it's dynamesh version[closed] and still it gives me the same problems, black spots, but just in different areas,I even tried with a really lowpoly mesh, the problem remains...)
-The step just after applying the displacement is the one to apply a texture to the displacement, I tried applying a Noise Shader, but it covers the entire model, while Lee's one affects just the back of the head, how is that possible? Does anyone know what texture he used exactly? Even because he's effect looks really nice with it...
I also attached my Maya scene. Hopefully someone could have a look and help me out.
-The open mesh is the visible one once you'll open the file, if you want to give it a try with the closed one in the outliner is called "Dynamesh_geo"
-There are some shaders in the scene, the one you want to use(which is already applied to the mesh anyway) is the one called "PolyMeshToVolume01"
Link To the Scene: https://we.tl/t-MpDz7zOiEC
Replies (18)
Message 2 of 19
Message 3 of 19
lee_griggs
To reduce noise in volumes you must increase the lights volume samples.
Are you using displacement or volume displacement?
I use a ramp to determine where the displacement occurs.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 19
I'm using 6 light samples for each light and I set he resolution of the light to 3000
I never used Arnold before but if you take a look at my image at the end of the message "grapheditor" it shows that I connect the displacement to the node, doesnt that mean I'm using the "normal" displacement already?
Message 5 of 19
lee_griggs
That link is to the tutorial template. Try this link.
Lee Griggs
AUTODESK
Message 6 of 19
lee_griggs
Not light samples, volume samples in the light.
Lee Griggs
AUTODESK
Message 7 of 19
I took a look at the link to the tutorial template. I'm getting there, but not quite yet...
1)I increased the volume sampling of the light I have to 10, it' s still not white
2)Whenever I applied the displacement to the volume shader this is clearly visible on the head mesh, but on the vdb is like it's not there...I therefore increased the Output Max value to 50 just to see if it is affecting it in any way or not, and the result is reaaaaally weird, I don't get why I'm getting those squares, while the other half is not being affected at all(without displacement it renders just fine)
3)I don't get through which parameters you connect the range to the ramp and the ramp to the second projection...
Message 8 of 19
lee_griggs
1. Can you post renders and screengrabs of your settings and a simplified scene?
2. I don't know why it's not on the VDB. Yes, those squares are normal. You will just have to play around with the Range values and texture.
3. Its indicated in the screengrab at the bottom of the tutorial and its included in the scene file there.
Lee Griggs
AUTODESK
Message 9 of 19
Hey @Lee Griggs
Scene:https://we.tl/t-TySe0QCIdI
3)Mmh I might have been looking at a different tutorial but in the one I'm looking at there are no screenshots of any hypershade nodes at the bottom of the page...At most it's between the "tools" menu an image showing the graph, but this just shows that the 2 nodes are connected, but not which attributes are used for the connection...The scene that you attacched on the messagge above (Because there are no scene included in the tutorial) contains just a noise node connected to a standard volume shader, so not exactly what I need.
Thank you.
Message 10 of 19
lee_griggs
The tutorial with screengrab and scene file is here.
Lee Griggs
AUTODESK
Message 11 of 19
@Lee Griggs
I might be missing something, but that's the scene I was talking about, the graph node is really simple and contains just a noise node and a standard surface node...So it doesn't really explain what I need...
Message 12 of 19
lee_griggs
What do you need?
Lee Griggs
AUTODESK
Message 13 of 19
I don't get which parameters I need to change to make the vdb to behave properly, I changed every parameter possible and whatever I change the vdb always has that "big squares look"...The other thing, as said in the preiovus messagges is understand how to connect the range to the ramp and the ramp to the second projection since there isn't any graph showing how to connect these and the scene contains just a noise node and a standard surface(so no the 2 nodes I'm talking about, therefore I can't see how the connection has been made)
Message 14 of 19
lee_griggs
The blocks are a limitation of using high values in the Range shader. If you use a file texture it should be less noticeable. You will have to work around it, I'm afraid.
Lee Griggs
AUTODESK
Message 15 of 19
Hello @Lee Griggs
I managed to make the effect work and make the squares disappear by using an actual texture instead of a noise node. However, whenever I try to make a front view render the big square are always there, while when rendering from other angle these are way less if not even not existing...I tried to change texture and projection type, but this won't change the problem...Is there something else I am missing that affect the amount and look of these artifacts?
Thank you.
Message 16 of 19
lee_griggs
No, I have this problem too.
Lee Griggs
AUTODESK
Message 17 of 19
darioOrtisi
I would like to bring to your attention that the links do not work.
Message 18 of 19
Stephen.Blair
Documentation links from 2019 are not going to work, except that they redirect to the new home of the documentation.
In general, documentation for core Arnold shaders, shapes, lights, cameras, and other nodes, is found in the Arnold User Guide:
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_user_guide_ac_lights_html#volume-samples
Plugin-specific things like tutorials are found in the Plugin User Guide:
Help | Polymesh to Volume | Autodesk
// Stephen Blair
// Arnold Renderer Support
Message 19 of 19
darioOrtisi
Thanks @Stephen.Blair  i know that but it would important even all the requested by the user so someone can identify all the discussion. Anyway thank you.
