Is there a way to do an absolute override of the primary visibility parameter of all the objects inside an ass file.
At the moment a couple of objects in the ass have primary visibility off.
The override primary visibility in the attribute editor is only able to turn everything off.
Is it possible to do the reverse and turn it on for every object in the ass?
Use an operator and set visibility=255
or visibility += 1
If you want to only affect the shapes in the .ass file then you can use the following selection in the 'set_parameter' operator:
"*.(@type == 'shape')"
