Hello everyone, Has anyone ever experienced issues with rendering on Arnold using a MacBook Pro M1? I've been trying everything, but all the renders are filled with noise. If I attempt to apply the OptiX denoiser, it gives me this error (// Warning: WARNING |imager_denoiser_optix is unsupported in this build). This has been happening for about a year now; previously, my renders were perfect. Thanks in advance to everyone for your help.
The NVIDIA OptiX denoiser doesn't work on macs because there's no NVIDIA GPU in them. Hence the warning about this being unsupported in your build (your build being the macos build). Try instead the OIDN denoiser which also comes with Arnold. It works essentially in the same way but will run on macos.
Are you able to share your render settings samples? Any details about the scene would also be useful.
Tutorials on removing noise can be found here:
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_maya_tutorials_am_Removing_Noise_html
Thank you very much, for responding, I'll show you the character I was making, to which I just can't remove the grain
It looks like you are using sss? Try increasing the number of sss samples. Try 4. Only go higher if you see a noticeable difference.
3 skydome_light.samples should be enough.
I don't think specular samples need to be that high either.
Try increasing Camera (AA) samples to 4 or 5.
Do you need clamping?
Thank you very much the render is definitely improved, but always I see the whole thing unsharp, and poorly defined, should I fix it by always managing the values?
What do you mean by "unsharp"? Are you using any denoisers? What resolution are you rendering?
