Hi!
I am currently using the Arnold Render Engine for my porject. I am using the default software that comes with Maya 2019. For a few days now i am running into the following issue: When leaving the station at night, i apply Render Sequence for my project (I cannot batch render). When I come back in the morning, i always find my Maya closed (Crashed) and the render is not finished (Usually render around 100 frames before crashing). In the Event Viewer, i get the following messages:
And the Arnold Log gives me the following: Please advise as I cannot proceed with the process until this issue is solved. Thank you very much, Anton.There's no image attachments. You can post text from the logs.
Event Viewer messages won't help diagnose the problem. Either there's a specific problem with the scene, or perhaps you're running out of memory?
If you do a test batch render, say of 10 frames at a time, does that crash?
Can you enable file logging, so that you get a log file for each frame. Then check the memory usage from frame to frame.
I get the same problem. I noticed that after a while my ram is almost full. Every frame that gets rendered my ram gets fuller and fuller. I don't use tx files. I have 32gb ram.
Please ask a new question (this one is from Jul 2019).
And please attach an Arnold log for a few frames...
https://docs.arnoldrenderer.com/display/A5AFMUG/Log
