Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
MtoA 5.4.1.2 released
0 REPLIES 0
Message 1 of 1
Stephen.Blair
228 Views, 0 Replies
5.4.1.2 Bug Fixes
  • MTOA-1919 - Unable to cancel batch renders, reports "There is currently no render to cancel."
  • MTOA-1917 - Crash drawing render region in viewport
5.4.1.1 Bug Fixes
  • MTOA-1240 - Import Shaders does not create shadingEngine for volume shader
  • MTOA-1842 - Maya Arnold Viewport is not accounting for some camera film back settings causing geometry to be offset from the render
  • MTOA-1843 - Error message with XGen when creating clumps from guides
  • MTOA-1877 - If a floating point value is used for Frame Rate in Maya Arnold USD will export as framesPerSecond 0
  • MTOA-1879 - TX Manager crash on second failed conversion
  • MTOA-1881 - Non-render errors and warnings printed to script editor
  • MTOA-1891 - Error when assigning material on AiVolume node
  • MTOA-1896 - aiLayerRgba defaults to false for layer enable1 option
  • MTOA-1901 - Batch render fails on macOS
  • MTOA-1902 - Batch renders fail to open a port
  • MTOA-1903 - Windows cmd prompt launched on batch render
  • MTOA-1905 - ArnoldCreateDenoiser optionVar reset to true on launch
  • ARNOLD-6189 - strings with trailing backslashes result in corrupt .ass files: .ass writer now converts those to forward slashes
  • ARNOLD-11222 - Rare hang when reading .ass files that have certain sizes
  • ARNOLD-14899 - Random crash while deleting nodes from procedural_update
  • ARNOLD-14949 - Update expired lmutil certificate
  • ARNOLD-14698 - [MaterialX] Crash when reading document containing unknown node definitions
  • ARNOLD-14883 - [MaterialX] Crash in LookdevX/MaterialX when visualizing the dot node in the viewport
// Stephen Blair
// Arnold Renderer Support
0 REPLIES 0
