Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Maya ACES setup scene
13 REPLIES 13
Message 1 of 14
hyperviktor
1032 Views, 13 Replies
Could anyone possibly provide a maya scene with proper ACEScg setup and reference render to crosscheck our ACES setup ? There's so many confusing information about this it would be good to get a solid point of reference to crosscheck if everything works just fine.
Thank you!
Tags (2)
Labels (2)
13 REPLIES 13
Message 2 of 14
hyperviktor
in reply to: hyperviktor
Anyone with a scene file ?
Message 3 of 14
lee_griggs
What don't you understand about the workflow?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 14
hyperviktor
I'm unsure about the entire setup I have - I've downloaded ACES 1.2 from github, copied everything to C:\ACES\ folder and created an OCIO environment variable pointing to the OCIO config file.
First, I have no clue if there are any further steps to complete this setup.
Second, I'd like to see if the setup appears right is really the right one.
At this point my color picker in maya gives me 0.303 value non color managed for a 0.5 grey which is weird.
When I connect a tetxure to the aiStandar shader, regardless what input color p I'm using ( utility - srgb or anything really from the list ) the render looks exactly the same.
Basically , I'm trying to crosscheck every single step in the process to see if I did anything wrong and how things should function.
Message 5 of 14
brian_Foley
In Maya preferences - Color management did you set up for ACES?
You can follow this guide for ACES with Arnold to get your settings correct
https://docs.arnoldrenderer.com/display/A5AFMUG/ACES+Workflow
And I highly recommend this free script as an in-program guide and texture converter.
https://gumroad.com/liam_collod#ukVVo
Hope this helps.
Message 6 of 14
hyperviktor
No, it doesn't help, it comes across as patronising / taking the piss.
As I wrote earlier, I red all these articles / sources and I have a setup just like it is described in the Arnold docs.
I need to understand the steps of the setup and I need to be able to crosscheck what I've done is correct.
STEP1
I need to understand what are the files on github, why we copy them and where and if I did copy everything to the right place.
I have created an environment variable OCIO pointing to the config file, so every software supposed to read the same config which sounds fine.
STEP2
I have a full ACES setup exactly as described in the Arnold docs but I need to be able to verify that it is correct as I am seeing some weird things ( again, I did write this before ) - my 0.5 mid grey in the color picker when color management is turned off changes to 0.303 which is way off in my understanding and I don't know how can this happen or why.
Message 7 of 14
hyperviktor
So no one here who uses ACES has a sample maya project ? Really ?
Message 8 of 14
Hi
a scene won't help you if the rules are not setup correctly
in Maya Color Management:
OCIO Config Path: must point to: config.ocio (aces_1.2. or aces_1.1..)
Input Color Space: ACES-ACEScg
in aiImage or maya file:
Texture acting as beauty, color, or specular_color. must be set to: Utility-sRGB-Texture
Texture acting as data displacement, normal, bump, glossiness , roughness, specular, must be set to: Utility-RAW
Texture acting as environment exr, hdr, must be set to: Utility-Linear-Texture
by the way you have to provide a scene !
Message 9 of 14
hyperviktor
Dude, that is exactly my point, I am trying to figure if everything set up correctly, that is why I'm asking for a scene + a rendered .exr of that scene.
So if I render the scene on my system I have something to compare the render to.
BTW I have the setup as you've described and still don't get the right results.
I don't know why this is so difficult .. 😕
Message 10 of 14
can you put a simple test scene here!
just a teapot or a sphere
Message 11 of 14
hyperviktor
Sure, here it is - I was making this based on an article comparing sRGB linear vs ACES and my render with ACES still looks more like the sRGB example.ACES_color_box.zip
I had to ZIP it as it didn't like the Maya file.
Message 12 of 14
what do you expect to see ?
with & without OCIO
Message 13 of 14
hyperviktor
Seems this is my problem, my render looks like yours without version which is clearly wrong and I have no idea why.
Message 14 of 14
hyperviktor
Any idea why my render is different than your ACES render ?
Technology Administrators
