No, it doesn't help, it comes across as patronising / taking the piss.
As I wrote earlier, I red all these articles / sources and I have a setup just like it is described in the Arnold docs.
I need to understand the steps of the setup and I need to be able to crosscheck what I've done is correct.
STEP1
I need to understand what are the files on github, why we copy them and where and if I did copy everything to the right place.
I have created an environment variable OCIO pointing to the config file, so every software supposed to read the same config which sounds fine.
STEP2
I have a full ACES setup exactly as described in the Arnold docs but I need to be able to verify that it is correct as I am seeing some weird things ( again, I did write this before ) - my 0.5 mid grey in the color picker when color management is turned off changes to 0.303 which is way off in my understanding and I don't know how can this happen or why.
