Layer Shader does not accept input
VictorvdBrink
VictorvdBrink
I'm following this tutorial by Nextut for making a layered glass material.
But for some reason when it comes to using the aiLayerShader, it doesn't allow me to input any previously made aiStandardSurface. Which is clearly what is done in the video.
I made a small gif showcasing the problem.
(view in My Videos)
If anyone could help me out, I'd really appreciate it. Thanks alot in advance.
Stephen.Blair
Don't drag to the text box. Drag to the label. You'll an outline around both the label and text box.
(view in My Videos)
// Stephen Blair
// Arnold Renderer Support
rachid_1
That's because NEaiLayerShaderTemplate.xml is missing from ...MtoA\maya2024\scripts\mtoa\ui\templates.
So just copy/past this file where you installed  ...MtoA\maya2024\scripts\mtoa\ui\templates.
or add a variable to maya.env file and point to the xml file
MAYA_CUSTOM_TEMPLATE_PATH = point to xml.file
Hope this help!
VictorvdBrink
Yup...
That's a really dumb and small detail that is a huge UI oversight on Autodesk's part if you ask me.
But it works now. Thank you very much.
