how to make a custom motion vector AOV?
excentriPMNA2
excentriPMNA2
I followed the description --
https://support.solidangle.com/display/A5AFMUG/Custom+Motion+Vector+AOV+with+Motion+Vector+shader--
I can't make a custom motion AOV.
I had the following steps.
1. I make a custom AOV
2. I assign a motion vector shader to the custom AOV
3. set Start Time : 0, End Time : 1, and checked Encode Raw Vector in the Motion Vector Attributes.
4. In the render Settings window, I enabled motion blur, and Position : Center On Frame, and Length : 1
5. In the Render Settings windows, I checked "Ignore Motion Blur" in order to disable the motion blur effect.
What is my mistake?
Could you help me?
I have another question.
i don't know the role of the "Start Time" function and "End Time" function in the ai Motion Vector shader.
What is differences between them and "Start" attribute and "End" attribute under Motion Blur items in Render Settings window?
Replies (7)
lee_griggs
What happens when you try the scene file?
Lee Griggs
Arnold rendering specialist
AUTODESK
excentriPMNA2
my scene is
mymotion-blur.zip
lee_griggs
There is no motion vector shader in that scene. Download and use this scene.
Lee Griggs
AUTODESK
excentriPMNA2
I want both beauty aov(using other ai standard surface shader) and motion vector aov(using ai motion vector shader). but, your scene include motion vector node, and similar other shader. could you teach me how to make a custom motion vector aov and beauty aov(using other ai standard surface shader)?
lee_griggs
These tutorials will tell you how to do that.
Lee Griggs
AUTODESK
excentriPMNA2
but, your scene include motion vector only.
i used ai motion vector node in my scene.
on my own, i want to make a custom motion vector aov and beauty aov(using other ai standard surface shader).
excentriPMNA2
I realized the role of the motion vector shader.
The motion vector shader ouputs the motion vector with the motion blur enabled.
because of the reason, i think that the motion vector shader is unuseful in most cases.
